Ir para o conteúdo principal
WowWee Miposaur Battery Replacement
O que você precisa
  1. WowWee Miposaur Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use a Phillips head #1 screwdriver to remove 3 2mm screws from MiPosaur's underside panel.
    • You may need to use an extension on your screwdriver to work around small space between the panel and the dinosaur's leg.
    • You can remove the bottom screw completely, but the top two screws are captive and do not need to be removed entirely.
  2. WowWee Miposaur Battery Replacement: passo 2, imagem 1 %32
    • Firmly grasp the panel and pull apart from the base of the toy.
  3. WowWee Miposaur Battery Replacement: passo 3, imagem 1 %32
    • Remove the battery from the device.
Conclusão
Melissa Bender
Membro desde: 08/09/18
97 Reputação
Autoria de 1 guia
Equipe
iFixit, Team S1-G1, Weber Summer 2018 Membro de iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
Membros da 5
Autoria de 40 guias
Um comentário
Moving the MiPosaur along the ground will give it a burst of power, and so can create an electrical hazard when touching internal parts. If you keep moving it, the low battery sequence will commence and it will power off, even if the power switch is set to off. If you want to do this, drive it in fast circles.
Michael Deitz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 876
