Ir para o conteúdo principal
WowWee MiP Robot Tire Replacement
O que você precisa
  1. WowWee MiP Robot Tire Replacement, Wheel: passo 1, imagem 1 %32 WowWee MiP Robot Tire Replacement, Wheel: passo 1, imagem 2 %32
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  2. WowWee MiP Robot Tire Replacement: passo 2, imagem 1 %32 WowWee MiP Robot Tire Replacement: passo 2, imagem 2 %32
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: passo 3, imagem 1 %32
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: passo 4, imagem 1 %32 WowWee MiP Robot Tire Replacement, Tires: passo 4, imagem 2 %32
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: passo 5, imagem 1 %32 WowWee MiP Robot Tire Replacement: passo 5, imagem 2 %32 WowWee MiP Robot Tire Replacement: passo 5, imagem 3 %32
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
Conclusão
5 outras pessoas executaram este guia.
Moira Keahon
Membro desde: 09/24/14
257 Reputação
Autoria de 3 guias
Equipe
1Comentário do guia
my MiP has plastic over his wheels
Clarrie O'HARE - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 6,440
