Ir para o conteúdo principal
WowWee MiP Robot Battery Replacement
O que você precisa
  1. WowWee MiP Robot Battery Replacement, Battery: passo 1, imagem 1 %32 WowWee MiP Robot Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Battery Replacement: passo 2, imagem 1 %32 WowWee MiP Robot Battery Replacement: passo 2, imagem 2 %32
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
Conclusão
3 outras pessoas executaram este guia.
Moira Keahon
Membro desde: 09/24/14
257 Reputação
Autoria de 3 guias
Equipe
14Comentários do guia
Its a programmer MIP not this kind.
Azariah Trumble - Responder
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - Responder
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - Responder
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - Responder
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Sadie - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 89
Ao todo: 13,335
