Ir para o conteúdo principal
WowWee CHiP Robot Dog Wheel Replacement
O que você precisa
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: passo 1, imagem 1 %32
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: passo 2, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 2, imagem 2 %32
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: passo 3, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 3, imagem 2 %32
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 2 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 3 %32
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: passo 5, imagem 1 %32
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: passo 6, imagem 1 %32
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: passo 7, imagem 1 %32
    • Pull and remove wheel.
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Responder
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Responder
Heads up it is really hard to turn
Mary Pownsu - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 45
Ao todo: 4,612
