Ir para o conteúdo principal
WowWee CHiP Robot Dog Wheel Replacement
O que você precisa
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: passo 1, imagem 1 %32
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: passo 2, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 2, imagem 2 %32
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: passo 3, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 3, imagem 2 %32
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 1 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 2 %32 WowWee CHiP Robot Dog Wheel Replacement: passo 4, imagem 3 %32
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: passo 5, imagem 1 %32
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: passo 6, imagem 1 %32
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: passo 7, imagem 1 %32
    • Pull and remove wheel.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Responder
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 35
Duração total: 3,934
