Ir para o conteúdo principal
WowWee CHiP Robot Dog Smart Watch Battery Replacement
O que você precisa
  1. WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: passo 1, imagem 1 %32 WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: passo 1, imagem 2 %32
    • Place the Smart Watch on its back or side so that the full watch band is visible.
  2. WowWee CHiP Robot Dog Smart Watch Battery Replacement: passo 2, imagem 1 %32
    • Remove the wrist strap by gently pulling the band off of the plastic pegs on the back of the watch.
  3. WowWee CHiP Robot Dog Smart Watch Battery Replacement: passo 3, imagem 1 %32
    • Remove the four screws in the back of the watch using a Phillips #0 screwdriver.
  4. WowWee CHiP Robot Dog Smart Watch Battery Replacement: passo 4, imagem 1 %32
    • Gently pull off the back side of the watch component.
  5. WowWee CHiP Robot Dog Smart Watch Battery Replacement: passo 5, imagem 1 %32
    • Pull the battery and motherboard component out.
Conclusão
3 outras pessoas executaram este guia.
4 comentários
What batteries does the smart band use?
Yourmajesty100 - Responder
Can be replaced by one of these and some soldering.
https://www.adafruit.com/product/1317
Alto -
This doesn’t detail sourcing the replacement or un-soldering then soldering the battery.
This is just “WowWee CHiP Robot Dog Smart Watch Battery Inspection” Not Replacement.
Alto - Responder
But the discussion is under battery replacement
Daniel peters -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 3,257
