Ir para o conteúdo principal
WowWee CHiP Robot Dog Ear Replacement
O que você precisa
  1. WowWee CHiP Robot Dog Ear Replacement, Battery: passo 1, imagem 1 %32
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Ear Replacement: passo 2, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 2, imagem 2 %32
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Ear Replacement: passo 3, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 3, imagem 2 %32
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Ear Replacement: passo 4, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 4, imagem 2 %32 WowWee CHiP Robot Dog Ear Replacement: passo 4, imagem 3 %32
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Ear Replacement, Ear: passo 5, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement, Ear: passo 5, imagem 2 %32
    • Remove the 4 Phillips screws shown.
  6. WowWee CHiP Robot Dog Ear Replacement: passo 6, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 6, imagem 2 %32 WowWee CHiP Robot Dog Ear Replacement: passo 6, imagem 3 %32
    • Pull up top part of toy and remove the connecting wires.
    • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
  7. WowWee CHiP Robot Dog Ear Replacement: passo 7, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 7, imagem 2 %32 WowWee CHiP Robot Dog Ear Replacement: passo 7, imagem 3 %32
    • Remove the 4 Phillips screws to separate the head from the body.
  8. WowWee CHiP Robot Dog Ear Replacement: passo 8, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 8, imagem 2 %32
    • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
  9. WowWee CHiP Robot Dog Ear Replacement: passo 9, imagem 1 %32 WowWee CHiP Robot Dog Ear Replacement: passo 9, imagem 2 %32 WowWee CHiP Robot Dog Ear Replacement: passo 9, imagem 3 %32
    • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
Conclusão
1Comentário do guia
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
Michael Deitz - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 1,886
