Ir para o conteúdo principal
World Dryer Airforce J4-973A3 Server Board Replacement
O que você precisa
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, imagem 1 %32 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, imagem 2 %32 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: passo 1, imagem 3 %32
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: passo 2, imagem 1 %32 World Dryer Airforce J4-973A3 Server Board Replacement: passo 2, imagem 2 %32
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, imagem 1 %32 World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, imagem 2 %32 World Dryer Airforce J4-973A3 Server Board Replacement: passo 3, imagem 3 %32
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, imagem 1 %32 World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, imagem 2 %32 World Dryer Airforce J4-973A3 Server Board Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Conclusão
Blane Hirsh
Membro desde: 09/17/18
260 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 271
