Ir para o conteúdo principal
World Dryer Airforce J4-973A3 Sensor Board Replacement
O que você precisa
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: passo 1, imagem 1 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: passo 1, imagem 2 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: passo 1, imagem 3 %32
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 2, imagem 1 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 2, imagem 2 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 2, imagem 3 %32
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 3, imagem 1 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 3, imagem 2 %32
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 4, imagem 1 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 4, imagem 2 %32 World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 4, imagem 3 %32
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: passo 5, imagem 1 %32
    • Carefully remove the sensor board from your device.
Conclusão
Luke Clancy
Membro desde: 09/17/18
123 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 19
Duração total: 632
