Ir para o conteúdo principal
World Dryer Airforce J4-973A3 Air Filter Replacement
O que você precisa
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, imagem 1 %32 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, imagem 2 %32 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: passo 1, imagem 3 %32
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, imagem 1 %32 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, imagem 2 %32 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 2, imagem 3 %32
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: passo 3, imagem 1 %32 World Dryer Airforce J4-973A3 Air Filter Replacement: passo 3, imagem 2 %32
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
Conclusão
Blane Hirsh
Membro desde: 09/17/18
260 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 242
