Ir para o conteúdo principal
Wood Stool Leg Glide Replacement
O que você precisa
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: passo 1, imagem 1 %32
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: passo 2, imagem 1 %32
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: passo 3, imagem 1 %32
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: passo 4, imagem 1 %32
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: passo 5, imagem 1 %32
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: passo 6, imagem 1 %32
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: passo 7, imagem 1 %32 Wood Stool Leg Glide Replacement: passo 7, imagem 2 %32
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Conclusão
Molly Ristig
Membro desde: 10/07/19
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 308
