Ir para o conteúdo principal
Wolfgang Puck Pie Maker Disassembly
O que você precisa
  1. Wolfgang Puck Pie Maker Disassembly, Wolfgang Puck Pie Maker Disassembly: passo 1, imagem 1 %32
    • Open up the pie maker using the two main handles so it's open as shown in the picture.
  2. Wolfgang Puck Pie Maker Disassembly: passo 2, imagem 1 %32 Wolfgang Puck Pie Maker Disassembly: passo 2, imagem 2 %32
    • Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
    • Remove the inside handle cover.
  3. Wolfgang Puck Pie Maker Disassembly: passo 3, imagem 1 %32 Wolfgang Puck Pie Maker Disassembly: passo 3, imagem 2 %32
    • Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
    • This will allow for visibility into the wiring in the base.
  4. Wolfgang Puck Pie Maker Disassembly: passo 4, imagem 1 %32 Wolfgang Puck Pie Maker Disassembly: passo 4, imagem 2 %32
    • Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
    • Remove the top cover by pulling it off of the device.
  5. Wolfgang Puck Pie Maker Disassembly: passo 5, imagem 1 %32 Wolfgang Puck Pie Maker Disassembly: passo 5, imagem 2 %32
    • You now have access to the wiring underneath the top and bottom of the device.
    • To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
    • The temperature sensor can be accessed by lifting the bottom side of the device as shown.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 196
