Ir para o conteúdo principal
Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
O que você precisa
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: passo 1, imagem 1 %32
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 2, imagem 1 %32
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 3, imagem 1 %32
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 4, imagem 1 %32
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 5, imagem 1 %32
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 6, imagem 1 %32
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 7, imagem 1 %32
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 8, imagem 1 %32 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 8, imagem 2 %32
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: passo 9, imagem 1 %32
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 10, imagem 1 %32
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 11, imagem 1 %32 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: passo 11, imagem 2 %32
    • Remove the plunger from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Funchess
Membro desde: 04/19/18
715 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S22-G5, Maness Spring 2018 Membro de Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
Membros da 4
Autoria de 5 guias
4 comentários
Where does one get a new plunger for the replacement?
hsernaker - Responder
yes, where does one get a new pludger?
hiyar124 - Responder
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - Responder
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 1,158
