Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
Remove the crumb collector located on the bottom of the toaster.
Remove the three 8mm screws using the Tri-point Y1 screwdriver.
Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
Remove the final 8mm screw in the slide lever.
The lever can now pull away from the entire unit.
Remove toaster's outer shell by lifting straight up.
Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
Remove the outer shell from the device.
