Ir para o conteúdo principal
Wolf Gourmet WGTR102S Heat Dial Replacement
O que você precisa
  1. Wolf Gourmet WGTR102S Heat Dial Replacement, Outer Shell: passo 1, imagem 1 %32
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 2, imagem 1 %32
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 3, imagem 1 %32
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 4, imagem 1 %32
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 5, imagem 1 %32
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 6, imagem 1 %32
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 7, imagem 1 %32
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 8, imagem 1 %32 Wolf Gourmet WGTR102S Heat Dial Replacement: passo 8, imagem 2 %32
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Heat Dial Replacement, Heat Dial: passo 9, imagem 1 %32
    • Remove the two 4mm screws found on each side of the circuit board using a Tri-point Y1 screwdriver.
  10. Wolf Gourmet WGTR102S Heat Dial Replacement: passo 10, imagem 1 %32 Wolf Gourmet WGTR102S Heat Dial Replacement: passo 10, imagem 2 %32
    • Remove the circuit board from the device.
Conclusão
Ryan Funchess
Membro desde: 04/19/18
697 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S22-G5, Maness Spring 2018 Membro de Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 459
