Ir para o conteúdo principal
Introdução
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
  1. Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Remove the crumb collector located on the bottom of the toaster.
    • Remove the crumb collector located on the bottom of the toaster.
  4. Remove the three 8mm screws using the Tri-point Y1 screwdriver.
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Remove the final 8mm screw in the slide lever.
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Remove toaster's outer shell by lifting straight up.
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors. Remove the outer shell from the device.
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
    • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
  10. Use pliers to pull apart the three electrical connectors pictured in the graphic.
    • Use pliers to pull apart the three electrical connectors pictured in the graphic.
  11. Replace the electrical connectors.
    • Replace the electrical connectors.
Conclusão
Ryan Funchess
Membro desde: 19/04/2018
697 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team S22-G5, Maness Spring 2018 Membro de Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Membros
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 299
