Ir para o conteúdo principal
Wolf Gourmet WGBL100S Power Cord Replacement
O que você precisa
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: passo 2, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 2, imagem 2 %32
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: passo 3, imagem 1 %32
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: passo 4, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 4, imagem 2 %32
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: passo 5, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 5, imagem 2 %32
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: passo 6, imagem 1 %32
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: passo 7, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 7, imagem 2 %32
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, imagem 2 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 8, imagem 3 %32
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: passo 9, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 9, imagem 2 %32
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: passo 10, imagem 1 %32 Wolf Gourmet WGBL100S Power Cord Replacement: passo 10, imagem 2 %32
    • Wrap all the connections in electrical tape or heat shrink tubing.
Conclusão
To reassemble your device, follow steps 1-5 in reverse order.
Uma outra pessoa concluiu este guia.
Cole Gillespie
Membro desde: 04/19/18
476 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S25-G16, Maness Spring 2018 Membro de Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 228
