Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
If your blender is leaking or making strange noises, consider replacing the O-ring.
  1. Flip over the pitcher to expose the base of the blade assembly.
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Using a pair of pliers, pull of the drive shaft coupling.
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut. Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  5. Remove the nut using a crescent wrench.
    • Remove the nut using a crescent wrench.
  6. Push the blade assembly into the jar.
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
  7. Use tweezers to pull off the o-ring. Be careful not to cut yourself while handling the blender blades.
    • Use tweezers to pull off the o-ring.
    • Be careful not to cut yourself while handling the blender blades.
Conclusão
Luke Kutz
Membro desde: 19-04-2018
342 Reputação
3 Guias de autoria
equipe
Cal Poly, Team S25-G16, Maness Spring 2018 Membro de Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 63
