Ir para o conteúdo principal
Wolf Gourmet WGBL100S Blades Replacement
O que você precisa
  1. Wolf Gourmet WGBL100S Blades Replacement, Blender Blades: passo 1, imagem 1 %32
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Wolf Gourmet WGBL100S Blades Replacement: passo 2, imagem 1 %32
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Wolf Gourmet WGBL100S Blades Replacement: passo 3, imagem 1 %32 Wolf Gourmet WGBL100S Blades Replacement: passo 3, imagem 2 %32
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  4. Wolf Gourmet WGBL100S Blades Replacement: passo 4, imagem 1 %32
    • Remove the nut using a crescent wrench.
  5. Wolf Gourmet WGBL100S Blades Replacement: passo 5, imagem 1 %32
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
Conclusão
Uma outra pessoa concluiu este guia.
Luke Kutz
Membro desde: 04/19/18
354 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S25-G16, Maness Spring 2018 Membro de Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
Membros da 4
Autoria de 5 guias
Um comentário
Can anyone advise where to buy replacement blade
Nikki Turturro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 782
