Ir para o conteúdo principal
Wintec Filemate Clear 7" Battery Replacement
O que você precisa
  1. Wintec Filemate Clear 7" Battery Replacement, Remove the Backplate: passo 1, imagem 1 %32
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Battery Replacement: passo 2, imagem 1 %32 Wintec Filemate Clear 7" Battery Replacement: passo 2, imagem 2 %32
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Battery Replacement, Remove the Battery: passo 3, imagem 1 %32
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Battery Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Battery Replacement: passo 5, imagem 1 %32
    • Fully remove the battery from the device.
Conclusão
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 outras pessoas executaram este guia.
Nicholas Ferraro
Membro desde: 01/20/15
431 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 19-6, Blackwell Spring 2014 Membro de USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
Membros da 3
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 971
