Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the air intake cover by placing your hands at the top of the air intake cover and gently pulling away from the device.
Detach the air intake screen by placing your fingers on the top two hinges.
Gently press the two hinges down and pull away from the device.
Using your vacuum, clean the other side of the air intake screen.
Remove the Activated Carbon Pre-Filter by pulling it away from the device.
Remove the True HEPA Filter by pulling it away from the device.
Replace the True HEPA Filter by inserting it into the empty space in the device.
Replace the Activated Carbon Pre-Filter by inserting it into the space in front of the True HEPA Filter.
Attach the air intake screen by placing the bottom two hinges in the bottom two holes of the device.
Using your fingers, gently press down on the top two hinges while placing them in the top two holes of the device.
Attach the air intake cover by gently pressing the top of the cover against the device.
7 outras pessoas executaram este guia.
5 comentários
Very easy to replace. Breeze.
@tackerman Where can I get a replacement air intake screen (the mesh ‘Pre-Filter’?) Mine has a tear in it and I can't find a replacement anywhere online. Thanks!
You can just scotch tape the tear (from two sides) if it is not too big
My Winix C535 came with two air filters. This video should only shows one. So is it supposed to have two filters inserted?
No, it's likely yours came with an extra replacement filter with the purchase. Their should only be one HEPA filter followed by one carbon filter and then lastly the mesh pre filter screen that locks into place.
