Introdução
Tearing down my door alarm to see what's broken - it should beep hard but it isn't. It's a pretty fragile thing that could use some new fixation. (I didn't photograph the magnet that's next to it but it exists and the alarm stops when it is close to the device).
O que você precisa
There is a screw hidden underneath the adhesive strip. Screw it open to get in
Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
This will definitely wake me up when there's someone opening my door! Fixed
