Introdução
Tearing down my door alarm to see what's broken - it should beep hard but it isn't. It's a pretty fragile thing that could use some new fixation. (I didn't photograph the magnet that's next to it but it exists and the alarm stops when it is close to the device).
Peças
Não são necessárias peças.
  1. This is a beautiful not-alarming alarm This is a beautiful not-alarming alarm
    • This is a beautiful not-alarming alarm
  2. There is a screw hidden underneath the adhesive strip. Screw it open to get in
    • There is a screw hidden underneath the adhesive strip. Screw it open to get in
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm) Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
    • Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
  5. The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
    • The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
    • This will definitely wake me up when there's someone opening my door! Fixed
Conclusão
Anke
122 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 24
