Ir para o conteúdo principal
Wileyfox Spark Plus Screen Replacement
O que você precisa
  1. Wileyfox Spark Plus Screen Replacement, Screen: passo 1, imagem 1 %32
    • Unscrew the 11 Phillips head screws under the backplate
  2. Wileyfox Spark Plus Screen Replacement: passo 2, imagem 1 %32
    • Insert a spudger and pry off the join between the screen and the middle frame.
  3. Wileyfox Spark Plus Screen Replacement: passo 3, imagem 1 %32
    • Pry off the motherboard after removing the ribbon cables and screws, Be careful, as there are wires on either side of the bottom of the board.
    • After removing the speaker from the top, flip the phone over and apply heat evenly across the display. Using a suction cup carefully lift off the display
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure to add the included adhesive.
Uma outra pessoa concluiu este guia.
Meow Meow Meowy
Membro desde: 01/04/21
181 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 281
