Vídeo de Apresentação
  1. Broken screen ? that's a pity You'll need hot air. Not too much thought, you'll melt the plastic otherwise Now just pry it open SLOWLY and apply heat.
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Nice, I see you've got the cover off Disconnect the battery (not with a metal tool) Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Get the battery out (don't bend it too much) Disconnect the LCD ribbon Disconnect the cameras
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  5. Unscrew anything you see Take the SIM trays out Take the motherboard out. You will have to disconnect to ribbon cables
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  6. Two screws here To take this guy out, you can use heat again Aaaaand with more heat, you will get the screen panel out !
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
Conclusão
4 outras pessoas concluíram este guia.
Alexandre Isaac
1.182 reputação
7 Guides authored
Equipe
Phone Repair Toulouse Membro de Phone Repair Toulouse
Business
1 Membro
13 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Todo: 1,045
