Introdução
This guide will help you to replace the speakers if you are experiencing audio issues.
O que você precisa
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
6 outras pessoas executaram este guia.
Um comentário
Awesome guide, replacement speakers worked flawlessly!!
