Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will help you to remove the outer case and be able to open the Nintendo Wii U Gamepad. You will need a Tri-WIng Y1 screw driver.
O que você precisa
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
4 outras pessoas executaram este guia.
2 comentários
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
