Ir para o conteúdo principal
Wii U GamePad Outer Case Replacement
O que você precisa
  1. Wii U GamePad Outer Case Replacement, Battery: passo 1, imagem 1 %32
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: passo 3, imagem 1 %32 Wii U GamePad Outer Case Replacement: passo 3, imagem 2 %32 Wii U GamePad Outer Case Replacement: passo 3, imagem 3 %32
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: passo 4, imagem 1 %32 Wii U GamePad Outer Case Replacement, Outer Case: passo 4, imagem 2 %32 Wii U GamePad Outer Case Replacement, Outer Case: passo 4, imagem 3 %32
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: passo 5, imagem 1 %32
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
Conclusão
4 outras pessoas executaram este guia.
Valentina Cerruty
Membro desde: 02/10/16
3.093 Reputação
7 Guias de autoria
Equipe
USF Tampa, Team 1-6, Sullivan Spring 2016 Membro de USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Membros
34 Guias de autoria
2 comentários
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - Responder
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 172
Duração total: 4,700
