Ir para o conteúdo principal
Wii U GamePad Camera Replacement
O que você precisa
  1. Wii U GamePad Camera Replacement, Battery: passo 1, imagem 1 %32
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Camera Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery plate.
  3. Wii U GamePad Camera Replacement: passo 3, imagem 1 %32 Wii U GamePad Camera Replacement: passo 3, imagem 2 %32 Wii U GamePad Camera Replacement: passo 3, imagem 3 %32
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Camera Replacement, Outer Case: passo 4, imagem 1 %32 Wii U GamePad Camera Replacement, Outer Case: passo 4, imagem 2 %32 Wii U GamePad Camera Replacement, Outer Case: passo 4, imagem 3 %32
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Camera Replacement: passo 5, imagem 1 %32
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
  6. Wii U GamePad Camera Replacement, Speakers: passo 6, imagem 1 %32 Wii U GamePad Camera Replacement, Speakers: passo 6, imagem 2 %32
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad Camera Replacement: passo 7, imagem 1 %32 Wii U GamePad Camera Replacement: passo 7, imagem 2 %32
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Wii U GamePad Camera Replacement, Bluetooth: passo 8, imagem 1 %32 Wii U GamePad Camera Replacement, Bluetooth: passo 8, imagem 2 %32 Wii U GamePad Camera Replacement, Bluetooth: passo 8, imagem 3 %32
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. Wii U GamePad Camera Replacement: passo 9, imagem 1 %32 Wii U GamePad Camera Replacement: passo 9, imagem 2 %32
    • With your fingers, lift and remove bluetooth board.
    • Remove the board carefully as there are still two wires attached.
  10. Wii U GamePad Camera Replacement: passo 10, imagem 1 %32 Wii U GamePad Camera Replacement: passo 10, imagem 2 %32
    • Disconnect the black and white wires off of the back of the bluetooth module.
  11. Wii U GamePad Camera Replacement: passo 11, imagem 1 %32
    • Lift and remove the bluetooth module.
  12. Wii U GamePad Camera Replacement, Motherboard: passo 12, imagem 1 %32
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad Camera Replacement: passo 13, imagem 1 %32 Wii U GamePad Camera Replacement: passo 13, imagem 2 %32
    • Remove the blue connector using tweezers.
  14. Wii U GamePad Camera Replacement: passo 14, imagem 1 %32 Wii U GamePad Camera Replacement: passo 14, imagem 2 %32
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
  15. Wii U GamePad Camera Replacement: passo 15, imagem 1 %32
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad Camera Replacement: passo 16, imagem 1 %32 Wii U GamePad Camera Replacement: passo 16, imagem 2 %32 Wii U GamePad Camera Replacement: passo 16, imagem 3 %32
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad Camera Replacement: passo 17, imagem 1 %32 Wii U GamePad Camera Replacement: passo 17, imagem 2 %32
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad Camera Replacement: passo 18, imagem 1 %32 Wii U GamePad Camera Replacement: passo 18, imagem 2 %32 Wii U GamePad Camera Replacement: passo 18, imagem 3 %32
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Wii U GamePad Camera Replacement, Camera: passo 19, imagem 1 %32 Wii U GamePad Camera Replacement, Camera: passo 19, imagem 2 %32
    • Flip motherboard over.
    • Remove the metal housing around the camera with tweezers.
  20. Wii U GamePad Camera Replacement: passo 20, imagem 1 %32
    • Pull the camera out using the tweezers.
Conclusão
Valentina Cerruty
Membro desde: 02/10/16
3.093 Reputação
7 Guias de autoria
Equipe
USF Tampa, Team 1-6, Sullivan Spring 2016 Membro de USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Membros
34 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 38
Duração total: 1,582
