Introdução
Use this guide to replace the back panel on your Nintendo Wii U GamePad.
O que você precisa
Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
11 outras pessoas executaram este guia.
2 comentários
and the front?
