Ir para o conteúdo principal
Wii U GamePad Back Panel Replacement
O que você precisa
  1. Wii U GamePad Back Panel Replacement, Battery: passo 1, imagem 1 %32 Wii U GamePad Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Back Panel Replacement: passo 2, imagem 1 %32 Wii U GamePad Back Panel Replacement: passo 2, imagem 2 %32 Wii U GamePad Back Panel Replacement: passo 2, imagem 3 %32
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 Wii U GamePad Back Panel Replacement, Back Panel: passo 3, imagem 2 %32 Wii U GamePad Back Panel Replacement, Back Panel: passo 3, imagem 3 %32
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Back Panel Replacement: passo 4, imagem 1 %32 Wii U GamePad Back Panel Replacement: passo 4, imagem 2 %32
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
Conclusão
11 outras pessoas executaram este guia.
Kim Arre
Membro desde: 01/11/13
4.960 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 17-20, Forte Winter 2013 Membro de Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
Membros da 5
Autoria de 39 guias
2 comentários
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 162
Duração total: 14,938
