Ir para o conteúdo principal
Wii U GamePad Battery Replacement
O que você precisa
  1. Wii U GamePad Battery Replacement, Battery: passo 1, imagem 1 %32 Wii U GamePad Battery Replacement, Battery: passo 1, imagem 2 %32
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Battery Replacement: passo 2, imagem 1 %32 Wii U GamePad Battery Replacement: passo 2, imagem 2 %32 Wii U GamePad Battery Replacement: passo 2, imagem 3 %32
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
Conclusão
22 outras pessoas executaram este guia.
Kim Arre
Membro desde: 01/11/13
4.888 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 17-20, Forte Winter 2013 Membro de Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
Membros da 5
Autoria de 38 guias
7 comentários
I only see two pins on most 3rd party rechargeable Li-Ion batteries. What is the pinout for the factory supplied battery? I would like to replace the battery with a similar 3.7v Li-Ion battery from somewhere like adafruit.
roof tip - Responder
I found an answer to my first question. My follow up question is if you can use a battery with only two charging pins and not the temp sensor pins?
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Steven Chiu - Responder
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
Chris - Responder
The size #00 is just a little smaller than the #0. When we wrote these guides, we used whatever worked for us. Either should work, but generally you should use the largest that will work to avoid stripping the screw.
Kim Arre -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 121
Últimos 30 dias: 419
Duração total: 30,828
