Introdução
In this simple and straightforward guide we will show you how to disassemble and replace the joystick and buttons of a Wii Nunchuk controller. You may need to replace the buttons and joystick if they stop working or you may just want to give the area a good careful clean with isopropyl alcohol.
O que você precisa
Use a Tri-point Y0 screwdriver to remove the two 9.2 mm screws from the back of the controller.
Quase terminado!
Conclusão
