Ir para o conteúdo principal
Wii Balance Board Frame Replacement
O que você precisa
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: passo 1, imagem 1 %32
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: passo 2, imagem 1 %32
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: passo 3, imagem 1 %32
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: passo 4, imagem 1 %32
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: passo 5, imagem 1 %32
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: passo 6, imagem 1 %32
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: passo 7, imagem 1 %32 Wii Balance Board Frame Replacement, Battery Compartment: passo 7, imagem 2 %32
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: passo 8, imagem 1 %32
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: passo 9, imagem 1 %32
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: passo 10, imagem 1 %32
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: passo 11, imagem 1 %32
    • Lift out the power supply. It is not screwed in.
Conclusão
Uma outra pessoa concluiu este guia.
Cory Olson
Membro desde: 09/29/14
936 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-8, Forte Fall 2014 Membro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Membros
Autoria de 16 guias
2Comentários do guia
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Responder
Hi, My batteries leaked over the UART_RX pin and I don't know how to fix it
Julián Rodríguez - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 93
Ao todo: 4,006
