Ir para o conteúdo principal
Wii Balance Board Foot Replacement
O que você precisa
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: passo 1, imagem 1 %32
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: passo 2, imagem 1 %32
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: passo 3, imagem 1 %32
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: passo 4, imagem 1 %32
    • Repeat steps two and three on the remaining four feet.
Conclusão
Cory Olson
Membro desde: 09/29/14
891 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-8, Forte Fall 2014 Membro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
Membros da 5
Autoria de 15 guias
2 comentários
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Responder
This manual did not help
nbrown1959.nb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 44
Duração total: 2,950
