Ir para o conteúdo principal
Wii Balance Board Battery Case Replacement
O que você precisa
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: passo 1, imagem 1 %32
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: passo 2, imagem 1 %32
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: passo 3, imagem 1 %32
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: passo 4, imagem 1 %32
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: passo 5, imagem 1 %32
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: passo 6, imagem 1 %32
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: passo 7, imagem 1 %32 Wii Balance Board Battery Case Replacement, Battery Compartment: passo 7, imagem 2 %32
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: passo 8, imagem 1 %32
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
Conclusão
16 outras pessoas executaram este guia.
Michelle Reed
Membro desde: 09/29/14
447 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-8, Forte Fall 2014 Membro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
Membros da 5
Autoria de 15 guias
14 comentários
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Responder
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Responder
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Responder
u rock - it totally worked
scottydecept - Responder
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 246
Duração total: 41,749
