Introdução
This guide will demonstrate how to replace the back cover of the Balance Board.
O que você precisa
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Remove the gray plastic ring from the actual foot by lifting it up.
Conclusão
