Ir para o conteúdo principal
Esta tradução pode não refletir as atualizações mais recentes do guia de fontes. Ajude a atualizar a tradução ou veja guia de fontes.
Why! NH57ADS M.2 SSD Replacement
O que você precisa
  1. Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, imagem 1 %32 Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, imagem 2 %32 Why! NH57ADS M.2 SSD Replacement, Battery: passo 1, imagem 3 %32
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, imagem 1 %32 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, imagem 2 %32 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: passo 2, imagem 3 %32
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, imagem 1 %32 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, imagem 2 %32 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: passo 3, imagem 3 %32
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: passo 4, imagem 1 %32 Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: passo 4, imagem 2 %32
    • Remove the Phillips screw securing the M.2 SSD drive in place. The end of the drive will pop up by a small amount.
    • Slide the drive out from the connector in a straight line. If you feel resistance, try raising it slightly.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
fr en
80%
Jerry Wheeler está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Felice Suglia
Membro desde: 06/15/13
33.538 Reputação
Autoria de 283 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 331
