Ir para o conteúdo principal
Whirlpool WGD4800XQ Thermal Fuse Replacement
O que você precisa
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: passo 1, imagem 1 %32
    • Unplug the dryer from the power outlet.
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 2, imagem 1 %32 Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 2, imagem 2 %32
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 3, imagem 1 %32
    • Lift the backplate off of the dryer.
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 4, imagem 1 %32
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 5, imagem 1 %32
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 6, imagem 1 %32
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 7, imagem 1 %32
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 8, imagem 1 %32 Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 8, imagem 2 %32
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: passo 9, imagem 1 %32
    • Connect the dryer to the power outlet.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 61
Duração total: 501
