Ir para o conteúdo principal
Whirlpool Refrigerator Water Inlet Valve Replacement
O que você precisa
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 4, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 4, imagem 2 %32
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: passo 5, imagem 3 %32
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: passo 6, imagem 1 %32
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: passo 7, imagem 3 %32
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: passo 8, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 8, imagem 2 %32
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 9, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: passo 9, imagem 2 %32
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement: passo 10, imagem 3 %32
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, imagem 1 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, imagem 2 %32 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: passo 11, imagem 3 %32
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: passo 12, imagem 1 %32
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: passo 13, imagem 1 %32
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 572 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 80
Últimos 30 dias: 438
Duração total: 3,543
