Ir para o conteúdo principal
Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement
O que você precisa
  1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the dispenser panels: passo 2, imagem 1 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the dispenser panels: passo 2, imagem 2 %32
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: passo 3, imagem 1 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: passo 3, imagem 2 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: passo 3, imagem 3 %32
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the control board: passo 4, imagem 1 %32
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: passo 5, imagem 1 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: passo 5, imagem 2 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: passo 5, imagem 3 %32
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: passo 6, imagem 1 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: passo 6, imagem 2 %32 Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: passo 6, imagem 3 %32
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the control board: passo 7, imagem 1 %32
    • Remove the control board.
Conclusão
Matt Zieminski
Membro desde: 02/23/15
41.382 Reputação
Autoria de 13 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.543 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 26
Ao todo: 201
