Ir para o conteúdo principal
Whirlpool Refrigerator Freezer Thermistor Replacement
O que você precisa
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, imagem 2 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: passo 3, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: passo 3, imagem 2 %32
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: passo 4, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement: passo 4, imagem 2 %32
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 2 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: passo 5, imagem 3 %32
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 2 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: passo 6, imagem 3 %32
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, imagem 2 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: passo 7, imagem 3 %32
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, imagem 1 %32 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: passo 8, imagem 2 %32
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: passo 9, imagem 1 %32
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: passo 10, imagem 1 %32
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro desde: 04/14/15
15.945 Reputação
Autoria de 89 guias
1Comentário do guia
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 27
Últimos 30 dias: 112
Ao todo: 3,817
