Introdução
Use this guide to remove or replace the freezer door in your Whirlpool Refrigerator.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Remove the screw(s) securing the freezer door wiring harness.
Remove the screw(s) securing the freezer door water hose.
Pull the wiring harness out of its slot in the chassis to access its connectors.
Disconnect any connectors attached to the door wiring harness.
Use one hand to compress the blue plastic ring into the green section of the hose.
Use the other hand to pull the water tube out of its slot.
Remove the screw(s) securing the freezer door.
Some devices may have screws solely for alignment. You don't need to remove these.
Pull the door hinge straight up to separate its alignment pins from the chassis.
Remove the door hinge.
Pull the freezer door straight up to disconnect it from the chassis.
Thread the cables through their slot in the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
Um comentário
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
