Ir para o conteúdo principal
Whirlpool Refrigerator Door Sensor Replacement
O que você precisa
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, imagem 1 %32 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, imagem 2 %32 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: passo 1, imagem 3 %32
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, imagem 1 %32 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, imagem 2 %32 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: passo 2, imagem 3 %32
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: passo 3, imagem 1 %32 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: passo 3, imagem 2 %32
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: passo 4, imagem 1 %32 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: passo 4, imagem 2 %32
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 572 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 125
Duração total: 1,772
