Ir para o conteúdo principal
Whirlpool Refrigerator Condenser Fan Replacement
O que você precisa
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 2 %32
    • Disconnect the connector attached to the condenser fan.
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 3 %32
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: passo 6, imagem 1 %32
    • Remove the screw(s) securing the condenser fan motor to the chassis.
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 1 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 2 %32 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: passo 7, imagem 3 %32
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
3 outras pessoas executaram este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 572 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 155
Duração total: 1,456
