Introdução
If your Whirlpool Duet Electric Dryer, model number WED9200SQ1 has not been working, it could be that the circuit board is malfunctioning and needs to be replaced.. In this guide, we will walk you through the steps to replace the malfunctioning circuit board. The main board in question is an integral part of your dryer's electrical system, distributing power to various components for safe and efficient operation. Before attempting this repair, it is crucial to unplug your dryer to prevent electric shock. Utilize ESD-safe tools to protect the dryer's electronic components from static damage.
O que você precisa
Use a T5 Torx screwdriver to remove two 6.3 mm screws. from the top back of the dryer.
Use the new circuit to put in the board. Ensure the two white hooks are connected to the metal part.
Use the T5 Torx screwdriver to screw the 6.3mm to the new circuit attached to the metal board. To do this part, move to the right that the screw should be tight.
The new circuit should be tight with the screw.
