Introdução
Use this guide to replace the main board a.k.a. Cycle Control Unit (CCU) on your Whirlpool dryer.
The main board is the "brain" of the dryer. When it fails, the dryer will operate erratically or not operate at all.
This guide will work for most Whirlpool dryers. This guide is written with a model WED87HED dryer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Ferramenta utilizada nesse passo:FixMat$36.95
Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Using a flat head screwdriver or a spudger, release the cover clips.
Lift the cover to release the tabs on the opposite side of the main board housing.
Remove the cover.
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95
Lift the board with one hand and use the other to release each clip with a spudger.
Repair didn’t go as planned? Ask our Answers community for help.
