Ir para o conteúdo principal
Whirlpool Dryer Control Panel Replacement
O que você precisa
  1. Whirlpool Dryer Control Panel Replacement, Safety Precautions: passo 1, imagem 1 %32
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: passo 2, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: passo 2, imagem 2 %32 Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Control Panel Replacement, Remove the top panel: passo 3, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Control Panel Replacement: passo 4, imagem 1 %32 Whirlpool Dryer Control Panel Replacement: passo 4, imagem 2 %32
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: passo 5, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: passo 5, imagem 2 %32
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Control Panel Replacement: passo 6, imagem 1 %32 Whirlpool Dryer Control Panel Replacement: passo 6, imagem 2 %32
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: passo 7, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: passo 7, imagem 2 %32
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Control Panel Replacement, Remove the control panel: passo 8, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Remove the control panel: passo 8, imagem 2 %32 Whirlpool Dryer Control Panel Replacement, Remove the control panel: passo 8, imagem 3 %32
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: passo 9, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: passo 9, imagem 2 %32 Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: passo 9, imagem 3 %32
    • Disconnect the wiring harness connectors.
    • Lay the control panel down on a towel or other soft surface to perform the next few steps.
  10. Whirlpool Dryer Control Panel Replacement, Unfasten the control board: passo 10, imagem 1 %32
    • Remove the screws which secure the front control board to its housing.
  11. Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: passo 11, imagem 1 %32 Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: passo 11, imagem 2 %32 Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: passo 11, imagem 3 %32
    • Lift up the back plate off the control panel and remove it.
    • The control panel is a circuit board attached to a face plate. Replace the entire unit if possible.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.579 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.855 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 42
Últimos 30 dias: 150
Ao todo: 3,082
