Ir para o conteúdo principal
Wexford CT-166TF Plastic Casing Replacement
O que você precisa
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: passo 1, imagem 1 %32
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: passo 2, imagem 1 %32
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: passo 3, imagem 1 %32
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: passo 4, imagem 1 %32 Wexford CT-166TF Plastic Casing  Replacement: passo 4, imagem 2 %32
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: passo 5, imagem 1 %32 Wexford CT-166TF Plastic Casing  Replacement: passo 5, imagem 2 %32
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: passo 6, imagem 1 %32 Wexford CT-166TF Plastic Casing  Replacement: passo 6, imagem 2 %32
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: passo 7, imagem 1 %32
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: passo 8, imagem 1 %32 Wexford CT-166TF Plastic Casing  Replacement: passo 8, imagem 2 %32
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: passo 9, imagem 1 %32 Wexford CT-166TF Plastic Casing  Replacement: passo 9, imagem 2 %32
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: passo 10, imagem 1 %32
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: passo 11, imagem 1 %32
    • Remove the two screws keeping the button attached to the top of the casing.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron Mattson
Membro desde: 04/05/17
101 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S3-G4, Liner Spring 2017 Membro de UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 341
