Ir para o conteúdo principal
Wexford CT-166TF Air Filter Casing Replacement
O que você precisa
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: passo 1, imagem 1 %32
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: passo 2, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 2, imagem 2 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 2, imagem 3 %32
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: passo 3, imagem 1 %32
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: passo 4, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 4, imagem 2 %32
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: passo 5, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 5, imagem 2 %32
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: passo 6, imagem 1 %32
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: passo 7, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 7, imagem 2 %32
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: passo 8, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 8, imagem 2 %32
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: passo 9, imagem 1 %32
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: passo 10, imagem 1 %32 Wexford CT-166TF Air Filter Casing Replacement: passo 10, imagem 2 %32
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Dannis Thompson
Membro desde: 04/10/17
261 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S3-G4, Liner Spring 2017 Membro de UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 615
